tire size affecting odometer?
94mx3precidia
Post by 94mx3precidia »
hey, would tire size affect the reading of the odometer? How does the odometer work? I know ive got bigger tires on my mx-3, i think there 205. So far it says ive driven roughly 140klm since i last reset the trip meter and it doesnt seem like ive traveled 140klm. I need some input on this situation, thanks.
1994 MX-3 GS KLZE, Probinator, Bully stage 1 (probe GT), B&M Short Shifter, 2 1/4" Custom headders back.
babyblueMX3
Post by babyblueMX3 »
yes tire size affects the speedometer
the height will, not the width.
205 is the width of the tire in mm
what's the other number. 55 ? (that number is the percentage of the width in thickness, that's the number you are looking for)
RIP 400whp ZE-T MX-3
94mx3precidia
im not sure what the numbers are, ill post them when i get home. How much would it affect the spedometer? enough to get pulled over? If the tire is bigger does it read that your going faster?
Thanks.
somebody posted this a while back but this will answer all your questions if you know what your car came with stock...
http://www.miata.net/garage/tirecalc.html
94mx3precidia
ok so ive done some reasearch and i think the stock size is 205/55r-15. right now im using 185/65r-14. Using the calculations mooneggs posted i get a difference of 1 mph. so all in all its not that bad, i was a little worried that i was goin too fast through the 40 zones in subdivisions.
you are exactly right. I'm using 205/55/15 on my slow car and now I have 185/65/14 on the fast car...
I can't remember the last time I did 40... :roll:
