how do i remove the HLA's
hey i have every thing off..im looking at the HLA's i can get the tops off but the springs are stuck in the holes how can i pull them out? is there a tool or just yank em ? manual doesnt say how to take em out jsut to take em out...
thanks
thanks
- Tunes67
Use a magnet.. just pull them up out of the bore off the top of the springs. The oil may cause slight vacuum lock but they will slide out of the bore if you pull up on them with enough force. This is assuming you have removed the cams.
Tunes67
Tunes67
- Tunes67
Those silver "Caps" are the HLA's. They sit on top of the springs...
Tunes67
Tunes67
- Tunes67
You dont have to remove the valves or valve springs to remove the heads. Just unbolt the heads from the block. If you really need to remove the valve springs.. it will be easier to do with the heads off the block anyway.
Tunes67
Tunes67
Um at this point i think you need to pick up a shop manual and do a little reading.... Not trying to be and a-- but if you gonna take the motor apart you may want it.96mx-3 wrote:ok so now im stuck on the head bolts...is it regular sockets? 13 fit but i think i made it skip 2wice with a breaker bar..any tips ?
Its a 12 point, you will need a medium extension and a breaker bar to get them out. Maybe sure you have all the inner and outer timing covers off first.
2002 Mazda Protege5 (Turbo kit 75% complete)
1996 Mazda MX-3 Gs KL-ZE
1994 Mazda MX-3 Rs (BP-T?)
there is also a pattern in which you take them out, YOU DO NOT JUST PULL THEM ALL OUT, and remeber once you remove the headbolts you need to go get new ones, as its not recomend that they be retorqued down again
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
