This unit can be installed on either Automatic or Manual Transmission vehicles
* This Alarm Will Fit Any Kind Of Auto, SUV, Truck Etc.
* The high tech-cutting edge technology of the most advanced alarm security system
* Automatic or Manual transmission
* Intelligent CAR Owner detection feature: ( as you approach your car with your remote, in 3 - 20m, the alarm system will disarm and unlock your car automatically without press the button )
* Long-distance remote control in noble design ( Over 2500 ft. paging alert distance range )
* Adopts the original microchip slice imported from the USA
* Auto locking door, convenient to get on / off the car
* Multiple features such: Central door lock, Car finder, Panic alarm, Trunk opening
* Brighten urgent signal in urgency
* New design for the 2-Way Communication+ Color LCD+REMOTE Engine Start
* Low waste battery with extended life
* Opening the baggage box by remote control
* Examination car appearance, spread mutual
* Adopting Keeloq jumps code technique to prevent illegal copy
* Alarm when the door is not properly closed
* Auto reply to alarm appearance
* Wide monitoring range:
Transmission: 500 meters
Feedback: 1,000 meters
* Two-way communication, color LCD panel
* Small-sized remote control with power-saving design
* LCD screen with illumination
* Alarm with sound, vibration and icon flash by remote control Ultrasonic or microwave sensor (optional)
* Power window output
* Dual-stage shock sensing reduces false alarm
* Remote sensor bypass
* Power interrupted memory
* Emergency override
* Valet mode
* Remote trunk release
* Automatic door lock / unlock
* Driver paging
* Car finder
* Remote arming / disarming
* Hands-free operation ( auto arming / disarming )
* Remote engine start
* Silent arming
* Auto rearming
* Auto arming ( selectable )
* Closing door reminder when arming
* Door open alert while driving ( selectable )
* Emergency alarm
* Anti-hijack
* Code learning
* Driver paging function : When the alarm is armed, you can page the driver only by tapping the communication module ( with paging sensor inside ) 3 times, usually mounted on the front windshield, the paging melody sound will sound 6 times from your remote control and "CALL" indication icon will flash on the LCD screen with vibrating. If you've already experienced waiting in a hot / cold parking lot where the driver is taking forever to return with no cell phone, or way to contact them, then you'll definitely need this function!
