rough idle
92blackmx3
rough idle
Post by 92blackmx3 »
so since i put a new water pump on my mx3 its been runnin really crappy low idle surges up and down when idle. checked the codes and got one for the egr valve and one for the pressure regulator. would the pressure regulator have to do with the gs fuel pump i have on it and would the egr help the rough idle i adjusted it and it still dont wanna run right
onlytrueromeo
Post by onlytrueromeo »
egr valve is pretty easy to clean out - my MX3 was running really rough and I got the EGR valve CEL as well. Take off the EGR valve, get yourself a nice bore brush / small rounded wire brush (like a plumbers wire brush for copper) and clean the piss out of the inside of it. Mine was gunked up with 1/8" of carbon. Some carb. cleaner to help with the process is nice too. You should probably replace the gasket when you do this too, it cost me $3 at the autoparts store. All together it was an $8 fix for me, and the car ran much better after!
92blackmx3
did you take your egr valve apart or just put the brush in the hole where the line goes if you took it apart how did you do that
torpedan
Post by torpedan »
you do not need to take it apart, just be sure the diaphram works (you can suck on the valve) and be sure there are not obstructions of the flow. Last EGR i worked on I used a bent fork to clean out.
Usually when you work on a car and then there is problems afterwards you need to inspect every part you touched, that is where odds are you problem will lie. Its possible you might have your vaccum lines messed up as well.
-torp.
I don't own a Mazda.
