neutral safety switch
anyone know where the neutral safety switch is on a mx-3 with an auto tranny? it needs to be replaced but have no idea where it is. thanks
Re: neutral safety switch
....do doautos have them.....I spose they might.?...JustinGT wrote:anyone know where the neutral safety switch is on a mx-3 with an auto tranny? it needs to be replaced but have no idea where it is. thanks
if so it'd be in 1 of 3 places:
-on/in the tranny
-on the shifter linkage near the tranny
-on the shifter linkage in the center console...
- PATDIESEL
They have a park switch, but I don't think they have a neutral switch. The park switch is on the shifter and goes to the ignition key. You can disable it if you just want it to work. Take the shifter apart and take the end out of the shifter, then let it sit just under the radio and I think it will work like that. However, it must stay either pressed in or out (cannot remember which) or the key will not work. It is easy to move if it goes to the position that it doesn't work in.
- mr1in6billion
