[WTT] Apexi RSM Loss-Power-Map for Mx-3 GS
Has anybody a complete mapped Loss-Power Map for a lowered V6 on Stock Tires and Rims and Stock Bodykit?
Master of big-bored throttlebody!
Mods:
Venom VCN-1000 NOS, custom lightened flywheel, 6pads race-clutch, custom big-bored-tb, modded fuel-pressure, race-header, 100cpi catalytic converter, 2 1/2" midpipe, short-shifter, 60/45mm KAW/Kayaba Suspension/Shock-Kit, Zimmerman Drilled Brake Disk, Stainless Steel Brake & Clutch Line, Exhaust Fogging System, Custom Made Alpha-N-Controlling, Apexi RSM, Water-Alcohol-Injection, 2 Lambda-Meter,
Mods:
meassured loss-power diagram is eventually the right word!?
With an Apexi RSM you can measure you power loose over the rolling resistance, wind resistance etc. it´s the correction table for the power measuring...
Mods:
Mods:
