[FS] I4 DOHC Motor, Tranny, ECU, Axles, Bumper, MORE!!!!
- ryanlindenberg
These parts are from a 1995 4 cyl.
ENGINE: 109,XXX miles. The motor ran fine when pulled from the vehicle. It didn't burn any oil or make any unusual noises. Mobil 1 full synthetic was always run in this engine. I believe the engine has all sensors and components except the TPS, starter, and alternator (I would have to look to make sure). The engine also includes the flywheel, clutch, and pressure plate (clutch didn't slip at all).
-$450 shipped
TRANNY: 109,XXX miles. 5 speed manual. The tranny shifted smooth, made no noise, and never caused any problems. I also ran full synthetic fluid in the tranny.
-$325 shipped
PM me if you are interested in the ECU, axles, bumper or stock intake components. The bumper is blaze red, but the paint is faded. I will also give discounts for buying multiple items. I would like to sell the motor and tranny as a unit but will separate if necessary.
Reason for removing the items from the vehicle was for a BPT swap. I need to get rid of these items ASAP because my parents are moving and no longer have room to store them. Items currently located in Grand Forks, ND. All prices are listed in USD and shipping is assumed to be within the lower 48 states.
-$450 shipped
-$325 shipped
Last edited by ryanlindenberg on May 28th, 2007, 12:29 pm, edited 1 time in total.
CARDOMAIN WITH UPDATED PICS
- ryanlindenberg
I forgot to mention that I also have a set of 4 OEM springs that are in good condition.
-$40 shipped
-$40 shipped
- ryanlindenberg
LOTS OF PICS!!!
I have spark plug wires that will go with the engine. The distributor cap/rotor and the plug wires have under 10,000 miles on them.
As you can see I have most of the stock intake components, including the MAF and an I4 SOHC cone airfilter adapter. The axles need new boots but the CV joints made no noise when removed. PM me for prices on these(or make an offer).
I also have to stock shifter ($10 shipped) and a stock fuel pump with strainer ($20 shipped).
- ryanlindenberg
nope, sorry. I hooked it up to the BPT.
- ryanlindenberg
engine and intake pieces are sold. MAF is still available though.
how much for just head and block and all internals?
1994 MX-3 1.6L B6DE 16v DOHC - rear disc swap, nix power steering/ac, Corksport f&r strut tower bars, Pedders urethane control arm bushings, urethane motor mounts, steel braided brake lines, painted dash, protege tranny
90 Miata w/ b6, Konig Lightspeed rims, Cams (boost to come soon)
74 Porsche 914 w/ 1.8L - restoration prooject
- ryanlindenberg
ryanlindenberg wrote:engine and intake pieces are sold. MAF is still available though.
sryryanlindenberg wrote:ryanlindenberg wrote:engine and intake pieces are sold. MAF is still available though.
skimmed and missed it
- ryanlindenberg
Items that I still have:
Bumper (pick-up only)
4 OEM springs
OEM shifter
upper tranny mount (manual DOHC)
SOHC cone filter adapter
OEM fuel pump
MAF (DOHC)
4 OEM springs
OEM shifter
OEM fuel pump
MAF (DOHC)
