Who here knows CAD?
Posted: May 12th, 2007, 3:21 pm
by Jdmtunedmx3
theres a website where you use a cad software to design what you want bulit and then it prices , you can choose finishes and etc. I dont know CAD or I would do it. I am looking to get some custom suspension parts made but I am not sure how to go about it. I want a lower tie bar, control arms, sway bars and etc.
http://www.emachineshop.com is the site. If anyone is willing to design this and get it over to them I will order it. Otherwise does anyone know where I can find these? I run autocross and would like my car to handle the best and upgrade parts other than a OEM replacement.
Thanks!
Re: Who here knows CAD?
Posted: May 13th, 2007, 11:31 am
by monty73741
if you care looking for some custom suspension goto luc's site, he got stuff on inserts & pics of parts tht he has made
jason
Posted: May 13th, 2007, 3:01 pm
by Custommx3
SRD closed down.
Posted: May 13th, 2007, 8:49 pm
by Jdmtunedmx3
so whats there to do?
Posted: May 13th, 2007, 9:41 pm
by PATDIESEL
You can download that program too. I've tried to use it and had mild success, but it would require some playing with or CAD skills to design such a part. You are going to need something that is Very well measured and I doubt you have to tools to measure so intricately. What class are you in Auto-X? Some classes will not allow such suspension mods. Also, there will not be enough benefit for the cost until you are a pretty good driver. It has been said to me many times, and at first I didn't like hearing it, but the best money you can spend to make you faster is on training yourself. Go to a driver training class at a racetrack or just keep entering races. Get other, more experienced drivers to ride with you. They are always willing to help a newer entrant to the sport. Thier advice is key to getting yourself to drive the car to its limits at the fastest it can handle. I'm sure you've gone past "your" limits, but doubt you have seen the MX-3s limits.
If you want to stiffen up the chasis, get a roll cage from Auto Power. They have a bolt-in rear kit that fits very well and a weld in front kit if you want a full cage. It will be less expensive than a one off lower control arm and cross member and will help the rigidity of the car much more. It will probably put you in a very high class in Auto-X though.
Posted: May 13th, 2007, 10:38 pm
by Cy
didn't read over the site much...
do they accept AutoCad2007 3D *.DWG files or any other format?...
something tells me no...they probably literally just email the CNC the plan from this program and run it...
Posted: May 14th, 2007, 10:49 am
by Jdmtunedmx3
I am not sure what type of files they use , I run in SM class.
Posted: May 14th, 2007, 11:27 am
by Mazdaracer
I played with the program for a bit, works VERY similar to CorelDraw, so it didn't take me too long to get the basics down. I'll keep playing with it and see what i can come up with.
Posted: May 14th, 2007, 12:14 pm
by Mnemonic
<certified Mechanical Computer Assistant Draftsman
Posted: May 14th, 2007, 11:55 pm
by Jdmtunedmx3
then you guys should be able to make this happen so we can get some parts rolling for us mx-3 peeps!
Posted: May 15th, 2007, 12:44 am
by Cy
I'm 99% sure that they would save a part # for possible future replications.... so if someone designs and orders a test part they'd easily be able to make more...
I Assume...?
Posted: May 15th, 2007, 10:56 am
by Jdmtunedmx3
I hope so!
Posted: May 24th, 2007, 12:35 pm
by Yoda
Cy wrote:I'm 99% sure that they would save a part # for possible future replications.... so if someone designs and orders a test part they'd easily be able to make more...
I Assume...?
Yes they do keep this info on file. I have used them to make brake,
suspension parts as well as other parts for other projects when the machine shop is over book or some time emachineshop is much cheaper that doing it ourselves.
In addition to knowing CAD you should also know what the machining equipment can and can't do, how many processes it will take to make the part, selecting the right material or in general a strong knowledge of Industrial Engineering even before creating the drawings. Drawing the part is one thing. Drawing it to be manufactures cost effectively is a whole other ballgame. The Emachineshop CAD programs is designed to look for conflicting processes but doesn't tell you that the part can be made cheaper if you do this instead of this.
