At my High School we have a machine that can bend metal and cut.
I might make a custom exhaust for my MX3 for about $40 (just the piping, no muffler, straight with not cat)
But while I am add it I might also make a intercooler aswell. Maybe serveral.
In the future I would like to run a T3 setup
So does anyone know measurements for a intercooler that would fit our MX3s?
What should be the diameter for the piping inlet and outlet pipe aswell?
As a matter of fact, if someone can get me a diagram or something with measurements of turbo piping I can get on that aswell
Need some quick measurements for a intercooler!
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
you might want to put this thread in the forced induction area
- babyblueMX3
Re: Need some quick measurements for a intercooler!
use the one we had use in the group buy for the turbo kits, IIRC i tried to fit the biggest intercooler WITHOUR modding anything (bumper, rebar, etc.)Juans_93_MX3 wrote:At my High School we have a machine that can bend metal and cut.
I'd run 2.25 in 2.5 out for the type of set-up you want.
RIP 400whp ZE-T MX-3
