Help Engine bucking
Help Engine bucking
I went through a car wash, now when I hit the gas my engine bucks like hell. Sounds like gas cuts out ? any ideas.
Got 2 B a KLZE
- PATDIESEL
You probably got water into some elec part. Let the car sit in the sun with the hood opened for awhile and it should stop. You should also look at the plastic intake pipe and make sure it isn't cracked or loose. Post back if that doesn't work and we'll go through some other more complicated ways of checking for the issue.
- Tunes67
Check and make sure you didnt get water in your distributor cap. Other than that.. as PAT says
Tunes67
Tunes67
