how to increase rear traction and stability during corners?
Posted: April 1st, 2007, 4:13 am
by kenken
i have a problem with my rear losing stability and traction during corners at about 100kph.
i'm using standard absorbers, Hotbits springs and 205/40/17 hankook rubbers.
anyone can help?
Posted: April 1st, 2007, 5:39 am
by yence
Adjust the rear camber settings. Giving it a slightly more negative camber will increase the amount of rubber touching the tarmac in corners.
Do you have a rear crossmember and rear strutbar yet? Those increase stability as well. Are you sure no parts of the rear suspension are worn?
Posted: April 1st, 2007, 12:51 pm
by lutos
I agree get a rear cross member made mine more tight
Posted: April 3rd, 2007, 6:42 am
by kenken
sorry man, i live in malaysia..its very hard to get performance parts for mx3. but i do know that strut bars can be custom made. do i need to remove all the plastic covers if i install rear strut?
my rear camber is 1'30"..is that ok?
Posted: April 4th, 2007, 2:10 am
by Steeb
play with the front and rear toe until you feel it is more suitable to your driving style.
Posted: April 7th, 2007, 11:09 am
by ryan_Fuerte
if you have a rear sway bar, you can make your own stab links out of heim joints, this allows the sway bar to be adjustable, and will handle like a gokart.
-Ryan
