Will these injectors fit...?
- Nomad_69er
I was just wondering if anyone knew if these would be a direct swap into a 95 MX3 RS (1.6L DOHC)?
Thanks!
http://cgi.ebay.ca/Mazda-Ford-Fuel-Inje ... dZViewItem
Thanks!
- xtreme velocity
i almost bidded on those..but i wasnt for sure either...
but if they do fit..they are all yours..
Current:
93 F-250 Diesel Coal Roller (For Sale)
06 RX-8 1.3 Rotary AT 6 speed (All looks)
79 Ford Courier 2.3 4cyl 5 speed (lil Pete)
Past:
05 Mazda RX-8 1.3 Rotary MT 6 speed
90 Mazda Miata 1.6L 5 speed 45k miles
94 MX-3 RS DOHC 5 speed 90k miles
Past:
- Limegreen mx-3
with out any tpye of fuel mangement ur stock setup won't control these injecters. ur injecters are around 190cc where the turbo probe/mx'6 are around 330cc. u'll run super rich and ur ecu will not control them.
- xtreme velocity
thats what my dad said but he wasnt sure on the cc's
glad i didnt bid..
glad i didnt bid..
Current:
Past:
Past:
Limegreen is correct, the biggest injector you can use on a 1.6 DOHC MX3 with the stock ecu alone is the 230cc injectors found in the 1.8 Miata or Protege. Anything larger and you will need a fuel controller (SAFC, Emanage etc) or standalone computer.
I am speaking from experience.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
- Nomad_69er
- MechaManZero
Since our injector pokes in the head a little doesn't that effect what type of injectors go in the B6DE. Because if I remember correctly when I had that motor, the injectors poked in the head.
Çlark
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
- OROutdoors
- Nomad_69er
