Is this setup good the way it is?
Posted: March 15th, 2007, 7:16 pm
by Whitey
I just put KYB struts and APEX spings on my mx. I noticed a little bit of camber once I got everything in. Just wondering if anyone else with this setup has added camber bolts or left it without?
Posted: March 16th, 2007, 9:25 am
by Trevor
No you need an alignment and proby a set of camber kits
Posted: March 16th, 2007, 10:29 am
by solo_ryder
Yea in most cases when you lower your car you knock the alignment and camber etc. off its norms. You should get a alignment right away, it doesnt hurt to get camber bolts though as you do not want to have to get two alignments.
Posted: March 16th, 2007, 12:19 pm
by Mooneggs
It NEVER hurts to put the camber kit on... $28 shipped off ebay all day long. Not too hard to install yourself. Definately recommended especially if you upgrade rim size to 17, 18 etc. That way when you go to have an alignment done you can get it done RIGHT! Or you can have the alignment shop put it on and they will probably charge you an arm and a leg...
Posted: March 16th, 2007, 4:46 pm
by Whitey
The camber kit I was looking at is adjustments between -1 and +1 degrees. Is this enough adjustment for a 1.8 in drop with 16 inch rims. There are other ones on ebay but this is the most common set of camber bolts that I saw.
