Is this setup good the way it is?
I just put KYB struts and APEX spings on my mx. I noticed a little bit of camber once I got everything in. Just wondering if anyone else with this setup has added camber bolts or left it without?
- solo_ryder
It NEVER hurts to put the camber kit on... $28 shipped off ebay all day long. Not too hard to install yourself. Definately recommended especially if you upgrade rim size to 17, 18 etc. That way when you go to have an alignment done you can get it done RIGHT! Or you can have the alignment shop put it on and they will probably charge you an arm and a leg...
