front end noise?
xcilver
front end noise?
Post by xcilver »
I am getting a noise from drivers side wheel area, it is getting louder and when I turn right it is louder! it runs smoother and quiet at top end.
any ideas?
Thanks!
neutral
Post by neutral »
Q is too broad. Since this is Internet diagnostics and you are the only one w/access to the car, need more info. Could be suspension or wheel/hub/axles or brake related, who knows? Is the noise
a clicking, thunk, knock, chatter etc?
how long has it been going on?
does it change on accel, deceleration, braking?
does it speed up when the wheels turn faster?
noticeable only at certain speeds? explain?
Do certain road conditions seem to cause it?
any known history of front end maint/repair work like new struts or CV joints/axles?
Post back.
Image -Jim
o0loopy0o
Post by o0loopy0o »
i think CV
xcilver
front end noise?
Post by xcilver »
ok, the engine was just swapped, we had to rip it all down so yes the front end was apart, the noise does increase and get louder with speed, it started out really quiet and has increased to the point it is starting to be felt in the gas peddle and steering! it is not loose at all, all is greased and booted, I noticed the cv joint has number marks on the rings and balls, does it have same marks in the joint? still there in neutral, breaks feel good, no tracking, just a rumble that winds up and is louder each week! thanks.
xcilver
front end noise
Post by xcilver »
I have got a whole front end to swap parts from as I need them... any sugggestions would be great!
tehbrookzorz
Post by tehbrookzorz »
I suspect wheel bearing or brakes.
Cody
lutos
Post by lutos »
its either going to be wheel bearing or axle mine had the same thing really mad shake at higher speeds also thou
Hayata
Post by Hayata »
i agree wheel bearing
ryan_Fuerte
Post by ryan_Fuerte »
I agree start with the wheel bearing
Mx-3 GSr : Rebuilt klde with 5spd swap, xtd stage 3 clutch, Magnaflow dual exhaust,Accord custom intake, kyb gr2 struts with eibach springs, civic dual halo projectors, black altezzas, white 15'' oz rims, rolling on dunlop street slicks.
http://www.cardomain.com/ride/2400330
