Idle question
Idle question
Is it normal for my idle to drop to 400ish RPM's when I push in the clutch at a light? If the clutch isn't in it's at 1000ish. Thanks in advance!
- PATDIESEL
Check your neutral switch on the trans. It sounds like it is broken or the wires have broken. The car should stay at a constant 750-1000 RPM.
