hi there mx3 lovers.
this is jasper from holland whit a technical question.
i drive a mazda mx3 2.0 V6, this engine is swapped from a mazda 323F ba/landis. the intake manifold used is from a kl-de 2.5l engine
now the question, since we've swapped the old k8 for the kf, i'm having some trouble's getting it running the right way, whit de k8 ecu it was running way to rich, and whit the k11 ecu the vriss points opened about 400rpm later.
now i found a kf01 ecu, can any-one telle me if that's the right ecu? it is a manual tranny... if not, what engine does this ecu come from?
thanx.
ecu question
spirit of oxigin
spirit of oxigin
spirit of oxigin
Hi, the KFZE is not a swap that is widely done and that is why you have got no answer. The KFZE swaps that has been done on this site has ended fairly poor at the best.
If you have the KL01 ECU then it comes from the KLDE. If you have an ECU which say KF01 I really have no clue.
I would suggest that you swap your KFZE to a KLDE or even KLZE. It would be a lot less hazzle.
'92 GS
My worklog
My worklog
