Hey guys, sadly I have to sell my baby, so I hope someone takes care of her as well as I did.
Its a base White RS with a 5 spd mtx.
255 000 kms
Engine:
Rebuilt head (at 252 000 kms):
-New Stem seals
-New cam seals
-Complete Valve Job
-New distributor assembly(cap rotor,disty, disty o ring, cap gasket)
-New Valve cover gasket
-New Head gasket
-New Timing belt
-New Timing idler and tensioner pulleys
also I replaced the crank seal and fuel filter and pcv valve while the head was off.
Compresion is above 180 in all 4 cylinders(Test done Feb 20, 2007)
Recent Front Brake Job (pads, rotors, calipers)
Replaced both CV axles
New Ball Joints,
New Outer Tie Rod Ends
Clutch Slave Cylinder, clutch and relaese and pilot bearings replaced at 238 000kms
NGK spark plug wires
Underdrive pulley
K&N cone Air filter
Complete Magnaflow Custom Exhaust from manifold back (2.25" piping, 16" Magnaflow resonator, and Magnaflow dual tip chamber style muffler)
The body is in decent condition with some rust around the rear wheel wells, its got Tinted windows 35% tint on door windows and 85% on rear hatch and 2 New Uniroyal Tiger Paw all season tires.
Im asking $3500 obo
[FS] 1995 Mazda MX-3 RS PRICE DROP $3500 cdn o.b.o.
- Timmie_g
- jschrauwen
- kiwi_MX3
- Location: Backpacking in Canada in vancouver 13march onwards
could be interested, mind you please wait a bit as im not going to
be in edmonton till april.
How do Non canadians go about insuring cars?
as i understand it if you let the insurance lapse the car
must pass a machinical inspection.
