Headers from Ebay (ssautochrome)
http://cgi.ebay.com/ebaymotors/KL-ZE-Ma ... 7041QQrdZ1
has anyone bought these or knows if they are any good? The price is really good, I'm just worried that its one of those things that you get what you paid for. Anyways, if anyone knows anything about these let me know
thanks
thanks
92 Mazda MX3 GS
http://www.cardomain.com/id/ukrman" onclick="window.open(this.href);return false; - cardomain page
viewtopic.php?f=46&t=66481 - worklog
viewtopic.php?f=37&t=72099 - feedback
viewtopic.php?f=2&t=71757 - stuff for sale
http://s2.metaldamage.com/c.php?uid=159229" onclick="window.open(this.href);return false; - biggest waste of time
![Image](http://i72.photobucket.com/albums/i181/ukrman28/MX-3/mx3comsignature2-2.jpg)
I have those on my car.
But I paid a bit more than $100 for them.
A pain to install, as it`s so tight to actually remove the old headers and get these on.
Also, you have to move the original cat backwards so it`s located right under the shifter linkage, wich sucks. I`m trying to find a solution to this, as this limits how much I can lower my car.
-n
-n
- papa roached
same headers i got, work good for me
- BornSticky
cut about 6" off the actual headers at the end and it fits perfect
they are ment to go on a probe or an mx-6 which is a longer car but same engine
#5389 to join MX-3.com
thanks for the input
92 Mazda MX3 GS
Do they compare to soemthing like Hot Shot or Bosal? It says that the unofficial dyno is 21 hp increase and 22 lbs of torque increase. Does that sound legitimate?
92 Mazda MX3 GS
nope-mx3 wrote:imho those numbers are not even close.Ukrman wrote:Do they compare to soemthing like Hot Shot or Bosal? It says that the unofficial dyno is 21 hp increase and 22 lbs of torque increase. Does that sound legitimate?
-n
what are they? are there any difference?
92 Mazda MX3 GS
- ryan_Fuerte
21hp is no were near what youd experience. If you put them on a k8, you might feel make a couple whp. Since the primarys are larger and meant for the 2.5L. Still a good bolt on mod, and when you wanna do an engine swap, you can just swap them over.
Mx-3 GSr : Rebuilt klde with 5spd swap, xtd stage 3 clutch, Magnaflow dual exhaust,Accord custom intake, kyb gr2 struts with eibach springs, civic dual halo projectors, black altezzas, white 15'' oz rims, rolling on dunlop street slicks.
http://www.cardomain.com/ride/2400330
the first time i installed them i had leaky front and rear just a bit.. when i swapped over to ze they fit like a glove. its WAY easier to install if you lift engine.
-hec
