Where are FE3 engines?
- Nomad_69er
What cars used them? Where were they used? And what makes them different/better than a BP? Thanks!
Bryan
Bryan
- Nomad_69er
I think it`s from a Kia. Not sure about the model though.
I expect it`s kinda expensive, since it`s a pretty new engine.
EDIT: Seems I was way of there
Actually a pretty old engine.
http://members.aol.com/solomiata/FE3.html
-n
-n
- Yoda
Most common source is the 1 Gen Kia Sportage for RWD applications. The SOHC and SOHC turbo version were is in North America in the 1 gen RWD 626. Other that the Sportage the DOHC version is a rare find these days especially for a FWD. You are talking about an engine that started life as a diesel truck engine and is mid 70 to early '80s technology. Don't even expect it to be anything close to plug and play. Being an ex diesel, it can take a lot of boost as it was originally design to have 18:1 compression seeing them built to over 1000hp isn't that far fetched although now the Mazda L series engines have taken over and used in several serie of motorsport racing.Nomad_69er wrote:Anyone know anything about these engines? How easy are they to swap?
- papa roached
isnt the SOHC motors the F2 and F2T and the DOHC the FE3
- Nomad_69er
Nomad_69er wrote:So Yoda, you're telling me the Kia Sportage with an FE3 has an 18:1 compression ratio? I doubt it. There have been a couple of people that have done the swap and I'm just curious at what had to be done to make the swap possible? Thanks for any help.
Bryan
Yoda wrote: Being an ex diesel, it can take a lot of boost as it was originally design to have 18:1 compression
- Josh
if anyone knows anything its Yoda, he said it was an EX diesel engine. and they have high compression. if you dont belive him then instead of asking on the forum, open a book and do some research.Nomad_69er wrote:So Yoda, you're telling me the Kia Sportage with an FE3 has an 18:1 compression ratio? I doubt it. There have been a couple of people that have done the swap and I'm just curious at what had to be done to make the swap possible? Thanks for any help.
Bryan
- Nomad_69er
If you just wanna keep going...you can find a stock replacement for $550 from any engine recycler. It's up to you how much work you want to do to "freshen it up" but I went this route for economy and plugged it right in and so far it's in great shape.
If you want to upgrade there are many options depending on your budget. You could do a full rebuild of your B6 and with a little massaging and some upgraded parts get a modest gain. Some guys have built and turbo'd their B6 with excellent results (this is my plan). Lots of guys swear by the BP swap, and although as engine swaps go it's very easy, it is more complicated and can be costly. Your lucky you are working with a 94' as the wiring is a bit simpler for the BP swap.
If you search the forum you'll find that this topic has been discussed over and over and over....and over. And then over again.
92-93 is simpler for BP swap - 94 is a bit difficult - it also depends on what year the BP engine is.
94 Mx-3 Precidia
- Yoda
As a gas engine the CR is more like 9.5:1. The RF and RF-TDi are still a very common engine in Europe. I've been talking to a guy in France making 310hp at the wheels with a RF-T with the boost cranked up and injecting shots of propane. He's doing low, low 12s 400m runs. What makes him this fast is that he is making over 500ft/lb of torque well under 4500rpm and never has to shift higher that 4 gear. The other advantage of the FE/ RF is that the bore and stroke are equal dimentions so you have a broad flat torque curve and good peak HP numbers. This usually leads to a high hp/L ratio than other engine like the BP, F2, FS, etc.Josh wrote:if anyone knows anything its Yoda, he said it was an EX diesel engine. and they have high compression. if you dont belive him then instead of asking on the forum, open a book and do some research.Nomad_69er wrote:So Yoda, you're telling me the Kia Sportage with an FE3 has an 18:1 compression ratio? I doubt it. There have been a couple of people that have done the swap and I'm just curious at what had to be done to make the swap possible? Thanks for any help.
Bryan
