ht leads
ht leads
when i start the engine and remove an ht lead you would expect to see the spark jump on the part of the lead that connects to the spark plug but on my car the spark jump happens at the distributor cap end of the lead, the sparks coming out of the rubber insulation and hitting the distributor holding screw. this doesnt happen when the lead is connected to the sparkplug, only when sparkplug end is dis connected, also i removed the sparkplug and it was black and the top of the piston was wet and there was a fuel smell from that sparkplug hole. the distributor appears to have a crack at the screw but the sparks coming out of the lead boot not the distributor cap. any help pls
forgot to add the engine sometimes pinks on start up of the engine but never under load. maybe just once a week and the car will lose a bit of power and use more fuel after a few days it will start to run good then pink when turned on again starting the problem all over again. could this be related to the fuel on top of the piston?
