annoying beeping won't stop
Posted: February 2nd, 2007, 7:02 pm
by ruthless_mx3
You know the buzzer that sounds when you turn the key to on, or forget your keys in, or forget your lights on. Well, the stupid thing won't ever shut off as long as the key is in the on position. Out of nowhere it just started and now I have to listen to it while I'm driving. I'm going crazy!!!
PLEASE HELP!!!!
I know this is also posted in electrical and lighting so if one of them needs to be deleted I understand and appologize in advance. I'm just desperate to get it stopped quick and need it to be seen by as many people as possible.
Thanks
Posted: February 2nd, 2007, 10:42 pm
by mitmaks
this is seatbelt warning beeper. Had this happen to my SE, then all of a sudden it went away. You have to rewire something under your ebrake cover/console. Search around it was posted before.
Posted: February 3rd, 2007, 1:49 am
by Mnemonic
remove your arm rest, disconnect the plug you see, right by the e brake (the large one) then you loop the system to where it always see's your seatbelt being connected. the constant beeping is from the sensor going bad. There used to be a how too but i think it got archived cause it was so old.
Posted: February 3rd, 2007, 3:18 am
by Custommx3
Moved to Electrical.
Posted: February 3rd, 2007, 7:23 am
by neutral
Posted: February 3rd, 2007, 9:40 am
by ruthless_mx3
Ok I've already done the under the seat seatbelt module beeping thing. Out of nowhere beep beep beep, Lean forward and seatbelt warning stops. Took care of that. The plug by the e-brake I have not tryed.
Tryed the key warning switch with no luck. Like talked about here a few replies down:
http://www.mx-3.com/phpbb2/viewtopic.ph ... g&&start=0
There is no sequence of 5 or 10 beeps, it is constant. I don't have airbags either.
If I unplug the bottom plug on the fusebox it stops, but so does the auto seatbelts. Car still starts and runs fine, but no seatbelts.
This is very wierd and annoying
Posted: February 3rd, 2007, 5:30 pm
by ruthless_mx3
Posted: February 3rd, 2007, 7:55 pm
by mitmaks
thats what happened to mine
Posted: February 4th, 2007, 10:01 pm
by Lookwuticando
Quirky electronics in those beeper units. Mine killed defrost but still worked on the other stuff. The best fix I've found is take the box out, pop the cover, find the beeper and take it out altogether
