93 K8 into a 98 626???
Posted: February 1st, 2007, 6:10 pm
by mazdamx3freak
im trying to put a k8 in my friends 626 v6 b/c his motor blew and im giving him a free k8 to use as a daily driver. is there anything i will have to change b/c his car is odb2 and mine is odb1......any help would be nice thanx!
Posted: February 1st, 2007, 6:20 pm
by kiwi_MX3
interesting, what size of motor is coming out of the 626? as ive seen
them here with 1.8's and 2.0's in them.
Id use the k8 as a short block swap and swap all the 626's intake, dizy
and radiator nose ( think there's two sensors on it for ob2 ) and
you might have to look at the fronk crank angle sensor?
else everything is the same. ( in theory )
if she runs to rich you could swap in the k8 injectors as they are rated
less than the 626's ones.
Posted: February 1st, 2007, 6:54 pm
by Nd4SpdSe
If its what I think it, that 626 has a KLDE 2.6L v6. You really want to put your 130hp 1.8l v6 in a car that had a 165hp 2.5l v6?
Posted: February 1st, 2007, 10:32 pm
by 1992blazeredgs
I think it could be made to work, if you swap over all the 2.5 sensors and accessories. The only problem i think you will run into is that you wont have an obdII ecu to match the k8. I dont know how hard it would be to source one, or how the motor would run with a kl ecu.
Nate
Posted: February 1st, 2007, 11:50 pm
by mazdamx3freak
1992blazeredgs wrote:I think it could be made to work, if you swap over all the 2.5 sensors and accessories. The only problem i think you will run into is that you wont have an obdII ecu to match the k8. I dont know how hard it would be to source one, or how the motor would run with a kl ecu.
Nate
well im giveing him the motor for free so, a 30hp lose is worth it right? and the KLDE ecu on K8's run like s--- ive tryed it already. But i still need to find out will the k8 euc plug into the odb2 harness? and what can i do about the extra O2 sensor? has anyone else tryed this before, ive herd of i guy on here that did itbut wonder how it went...hmmmm
![Confused :?](./images/smilies/icon_confused.gif)
Posted: February 1st, 2007, 11:59 pm
by Mnemonic
just go grab an obd1 wiring harness
Posted: February 2nd, 2007, 1:42 am
by hppwdn
No, the obdI ecu will not plug into an obdII harness.
In theory, if you put the K8 into the 626 and use the K8 injectors (~170cc) in the 626 IM the 626 ECU should run it much better than if you just swapped the IMs and kept the stock 220s.
As for the extra O2s, just use the exhaust manifolds from the 626 and you should have the correct locations for all the O2s.
Posted: February 7th, 2007, 10:44 pm
by JM1EC-V6
For the intake, i would recommend keeping the K8 one with it's injectors.
Swap the 626 coil packs and remove the K8 disty.
Swap 626 crank pulley and sensor.
The rest is just basic plumbing, and a K8 in a 626 is like a FS in it !
Posted: February 11th, 2007, 3:08 am
by Juans_93_MX3
Save all the trouble and just put a KLDE in it already
a 626 with a K8?
Oh man, can you say SLOW!?
![Throw Up :throwup:](./images/smilies/throwup.gif)
Isnt it also ILLEGAL to put a older year motor onto a newer year car?
Even since its for free I dont think its worth it. Espically seeing how the resale value will drop
Posted: February 11th, 2007, 3:26 am
by hgallegos915
why would it be illegal? also who would find out.. the block looks the same.. lol just do it already if its a daily driver and you dont care about performance.
