My ZE Turbo Setup Part list Am I missing anything?
This setup will at 1st only be pushing 7 to 10 psi on the ZE (note the mx-3 will not be a DD), This setup is designed to handle alot more, so if later on i want to mess with the engine internals i can.
Turbo:
Turbo Manifold + DP
Intercooler (probe gt XS engineering In/out)
cold pipes
tial 38mm wastegate
tial bov 50mm
tial bov flange with t pipe
Turbo t3/t4 (Garrett or Turbonetics)
oil drain and feed lines with fittings
3" exhaust piping
3" hiflo cat
Electronics:
megasquirt fuel management
MS wiring harness
Wideband AEM
GM style IAT Wells SU107
Coil packs (from 626) to work with the MS 3 vb921s
accell ignition wires 8.5mm
Autometer Cobalt series boost gauge
Slimline electric fans 2x 12"
Greddy Boost controler
Greddy Turbo Timer
Fuel:
walbro 255 fuel pump
Millinia S injectors
Aeromotive fuel pressure regulator
mbx fuel rail adapter
dual fuel feed lines with fittings
Misc:
2.5" couplers with 2.5" tbolt clamps
3" to 2.5" for tb to charge pipe
2" to 2.5" from turbo oulet to IC piping
weld work/other
Transmission:
ACT clutch
Turbo:
Turbo Manifold + DP
cold pipes
tial 38mm wastegate
tial bov 50mm
3" exhaust piping
3" hiflo cat
Electronics:
MS wiring harness
Wideband AEM
Greddy Turbo Timer
Fuel:
Misc:
weld work/other
Transmission:
ACT clutch
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
already got the fidanza on teh car now, and yea i've been thinking about getting the tb bored out though since the air is compressed its not gonna give as much performance as it would NA but still a cheap decent mod to do
I might just get it done, like i was saying I want to go ahead and build the turbo setup to run a decent amount of boost and do it right the 1st time and later when the motor takes a crap on me or i decide to build it up i can jsut pull teh motor out and start working on it. I dont see the purpose of spending money on buying the same parts (but better) over and over again
Looks like alot of us are going turbo this year ![Very Happy :D](./images/smilies/icon_biggrin.gif)
-hec
HAHAHA whats that, where's your mx-3 again? wait oh oh yea thats right ::crush:: ![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
hehehehe![Smile :)](./images/smilies/icon_smile.gif)
hehehehe
yea yea your right, so true, i'll just make sure i slam on brakes when i see you riding my tail bwhahahaha CHRIS GET OFF THE ROOF OF MY CAR!!! ::drives off::
if your gettin all that you might as well get something bigger than millenia S injectors or make sure you get the 310cc's atleast...running 10psi with the millenia injectors is commin pretty close to maxing them out unless you have water/alcohol injection or you only drive it when its really cold your goin to be detonating your engine
except if your a whiz at tuning
2006 best ET 14.43 @ 96.9mph
93 MX-3 GS-95 Curveneck klze, kl-01 cammed,homemade CAI,HEI module, chipped kl-07 ECU,UDP,KYB GR-2 struts,DropZone lowering springs, Toyo Proxes 4's 205-50-r15
parts to be installed:Turbo hot pipes,T04E/t3 50/63 57 trim, ssqv BOV, hks style 38mm wastegate
the rest of my turbo set up and IPP hp rebuild kit is in the NEAR future
SOON TO BE MX-3ZE-T
SOON TO BE MX-3ZE-T
A couple of things not on your list to keep in mind.
If you go with the hot pipes off ebay, you will need to
modify the front to back motor mount bracket and the side
to side stabilizer, I also took the oil pan off to have a drain
tube welded on, what a pain that was.
There is going to be maybe a 6-12 little things that will require
a run to the nearest hardware store such as brass nipples,tees,nuts
and bolts that didn't come with the new stuff.
good luck
Andy P. 93 GS 1.8T
good luck
Andy P. 93 GS 1.8T
- XxantwawnxX
guess it depends which ebay hot pipes you get...i needed no modification.
