WTB GS REAR ENGINE MOUNT
Posted: January 17th, 2007, 1:02 am
by hgallegos915
hey.. i need a transmission mount.. autozone only has the 4 cyl one not the v6.. anyone got it?
Posted: January 25th, 2007, 8:15 am
by ssmog
Try going to your local NAPA or other parts dealer. I replaced all my mounts 2 years ago after ordering them in from NAPA, in total all mounts only cost me approx. 250.00 Cdn.
Mine is the GS V6 but even so they can order them in for you.
Posted: January 25th, 2007, 10:37 am
by hoffman_BMX89
i have one but its garbage it needs to be filled by rear engine mount u mean the rear transmission mount bolted to the engine member brace right?
Posted: January 25th, 2007, 10:48 am
by ssmog
Correct me if I am wrong because it has been quite some time since I've had to do sort of mech. work to my GS other than reg. maint. and of course doing the repairs after i bounced a deer off the front clip, through the windshield and off the roof but if I recall there are 3 mounts in total under the hood, one attaching the front of the motor ( timing belt side), one located at the lower front bank connecting the cross member frames to the block and the other is located at the top of the trans. close to the tail stock/ gear box end of the trans.
I will have a look at my GS and make a call to my buddy at the Mazda dealer and see it the trans. mounts for the 4 and 6 cyl. models are the same, if they are the same and that is in fact the one you need ( trans. to side tubular frame near tail stock/ gear box) I have a spare and will pull it out of my shop and see about shipping it to you.
Cheers.
Posted: January 25th, 2007, 11:24 am
by mx3autozam
why don't you just get the Mazdaspeed ones from Corksport. Or if you get new ones from Napa or Mazda and fill them with Urethane. Don't bother filling your torn one. its pointless!
Posted: January 30th, 2007, 2:05 am
by hgallegos915
GOT EM here thanks
