WTB GS REAR ENGINE MOUNT
hey.. i need a transmission mount.. autozone only has the 4 cyl one not the v6.. anyone got it?
-hec
Try going to your local NAPA or other parts dealer. I replaced all my mounts 2 years ago after ordering them in from NAPA, in total all mounts only cost me approx. 250.00 Cdn.
Mine is the GS V6 but even so they can order them in for you.
Commit yourself to a Psychiatric hospital before the rest your sanity disappears, and you are strapped in a chair, fed mushy peas with a rubber spoon with only your tortured fantasies for comfort....
ssmog
ssmog
i have one but its garbage it needs to be filled by rear engine mount u mean the rear transmission mount bolted to the engine member brace right?
95 Mx-3 GS [R.I.P.]
96 Mx-3 GSR [Sold]
97 Mitsubishi eclipse spyder [For Sale]
97 Saturn SL2 [Sold]
03 Corvette Z06 [Current toy]
98 Saturn SL2 [Daily]
http://www.cardomain.com/ride/2176731" onclick="window.open(this.href);return false;
96 Mx-3 GSR [Sold]
Correct me if I am wrong because it has been quite some time since I've had to do sort of mech. work to my GS other than reg. maint. and of course doing the repairs after i bounced a deer off the front clip, through the windshield and off the roof but if I recall there are 3 mounts in total under the hood, one attaching the front of the motor ( timing belt side), one located at the lower front bank connecting the cross member frames to the block and the other is located at the top of the trans. close to the tail stock/ gear box end of the trans.
I will have a look at my GS and make a call to my buddy at the Mazda dealer and see it the trans. mounts for the 4 and 6 cyl. models are the same, if they are the same and that is in fact the one you need ( trans. to side tubular frame near tail stock/ gear box) I have a spare and will pull it out of my shop and see about shipping it to you.
Cheers.
Cheers.
ssmog
ssmog
- mx3autozam
GOT EM here thanks ![Very Happy :D](./images/smilies/icon_biggrin.gif)
-hec
