http://www.geocities.com/c00l.geo/oilstuff.jpg
ok I checked filter.. its tight. Checked the hose and its good no leaks. Appears to be leaking trough the grooves or the disk shaped thingy? any ideas? I think Ill swap over my k8 one not sure if its the same.
Leaking oil from here?
-hec
- ryan_Fuerte
ohhh hec a k&n performance filter, i heard they add 15 hp, as for your oil leak, if you take off the oil filter you will see a big nut (1 1/8' i think) on the threaded spigot. remove that and the coolant lines. The oil housing will split from the oil cooler. There is a oring in there that is the same as the orings that are on oil filters. mazda wanted 14 dollars for the oring, buy a $5 cheepie filter and use the oring off of it.
Mx-3 GSr : Rebuilt klde with 5spd swap, xtd stage 3 clutch, Magnaflow dual exhaust,Accord custom intake, kyb gr2 struts with eibach springs, civic dual halo projectors, black altezzas, white 15'' oz rims, rolling on dunlop street slicks.
http://www.cardomain.com/ride/2400330
- JM1EC-V6
Had a KL which was leaking from there. Took a K8 oil cooler and put on it. The K8 one has fewer plates , but i assumed that it was supposed to do the job on such a motor, K8 or KL.
Try to open it like the guy said, i didn't think about this before buying another one.
'94 Mx-3 GS-R SE, KL-ZE Interprep. (From '96 PGT KL)
1110Kg
-Interprep KL31 Spec.
ported heads, Polished combustion chamber,3 angle vlv job,10.3:1 C.R.,0.020'' O.S.,KL31 cam,-0.007'' heads,Long neck IM,KL31 TB, Hotshot headers,2.25'' exhaust,Magnaflow cat
![Image](http://img.photobucket.com/albums/1103/GSRBOMB/MY%20REALISATIONS/th_mazda_mx-3_Raphael_008-1.jpg)
![Image](http://img4.photobucket.com/albums/1103/GSRBOMB/257678_6_full.jpg)
![Image](http://img.photobucket.com/albums/1103/GSRBOMB/Photo013.jpg)
1110Kg
