WTB: Section of wire harness
Looking for an Item you'd like to buy? Post here.
This section is NOT for selling.
papa roached
Post by papa roached »
I need the 3 pin plug that goes to the disty and about 6-8 inches of pig tail wire after it, mine broke through because of age, need this to get my car back on the road
Vanished
Post by Vanished »
if you post a pic i shoudl be able to help you...i have 2 spare KLZE harness hanging around, that should work shoudln't it?
1992 Blaze MX-3 GS *R.I.P.*
1993 Blue 93 SE-ZE
http://www.cardomain.com/ride/2770987/2
Return to “MX-3 Related Want to Buy Forum”
