F2T swap!
F2T swap!
Going to pick up a probe gt on monday. The F2T is going into my car.... adventually.
Rebuild first.
anyways, il have pictures when i pick up the car monday.
- Bochek
Rebuild first.
- Bochek
- Limegreen mx-3
Re: F2T swap!
[quote="Bochek"]Going to pick up a probe gt on monday. The F2T is going into my car.... adventually.
Rebuild first.
145hp and 210tq stock, up boost to 15psi and your looking at 230hp and 300+tq WOOT!
- Bochek[/quote]
custom work is all i got to say if its going into ur mx-3 good luck man.
Rebuild first.
- Bochek[/quote]
- TREVO123
Gonna need standalone.. and alot of custom work, thats the other reason i didnt do it.
Great. Please post a comprehensive worklog with good detail so others can follow your footsteps if they wanted to.....
94 Mx-3 Precidia
ugh, why would i need a standalown? just gonna swap the harness and ecu
Why would you go with this motor instead of a B6T, BP (turboed) or a BPT which will be a simple drop in. The F2 motor will require lots of custom work, different tranny, mounts etc and really doesnt produce that much power.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
- neutral
Same question here. I have the F2 in my '90 MX-6 and doesn't look like a happy time to be had getting it to work in the MX-3 fwiw.osargeant wrote:Why would you go with this motor instead of a B6T, BP (turboed) or a BPT which will be a simple drop in. The F2 motor will require lots of custom work, different tranny, mounts etc and really doesnt produce that much power.
-Jim
- lowflyinmx3
why. because im getting the motor for free, and no, its only a 70 hp increase, but its over doubble the torque.
not only that, but did i mention its free?
and also, just to be different!
- Bochek
- Bochek
if we all only did what was easy then there wouldn't be many fun mx-3's or other cars out there.... like joshs AWD mx-3 and my (almost done) AWD mx-3) and i know i remember that either another mx-3 or protege swapped this engine in... just can't recall which but since they are pretty much the same engine bay it can be done
ProjectMx
My BP and AWD build thread
Cardomain
93 Escort GT daily driving
Cardomain
it worked great, for about 20 mins, and then the megasquirt crapped out, i still have not had enough time to figgure out why. and now that the winters here, the megasquirt will just be going on the f2t probably.
there is something wrong with the hall sensor imput circuit on the megasquirt.
- Bochek
- Bochek
thats awesome man. You definatly have to post up a work log. If you think about it, it shouldn't be that hard of a swap. As many Honda swaps you need different motor mounts, wiring harness, etc. Its just not as easy as a BPT swap, which who care you got it for free and once you get a zombie chip which ups the boost to 15psi you'll be taking any BPT with your huge torque. If anyone doubts this look on Probetalk.com and the E/Ts in a heavy first gen.
dohc b6, intake, exhaust, miata cams ready to go in
So you have narrowed it down to something wrong inside of the MS itself?Bochek wrote:it worked great, for about 20 mins, and then the megasquirt crapped out, i still have not had enough time to figgure out why. and now that the winters here, the megasquirt will just be going on the f2t probably.
- Bochek
Im caught between haltech and ms myself...
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
that is correct, i believe it has something to do with the value of the pullup resistor, because this is a known problem with the megasquirts, all hall sensors need a different value, perhaps mine is just on the edge of workingnos92mx3 wrote:So you have narrowed it down to something wrong inside of the MS itself?Bochek wrote:it worked great, for about 20 mins, and then the megasquirt crapped out, i still have not had enough time to figgure out why. and now that the winters here, the megasquirt will just be going on the f2t probably.
- Bochek
my next step will be to get a variable pot and replace the resistor with it, so that i can adjust the voltage.
- Bochek
