HLA Ticking / not ticking... strange behaviour
I have one problem.
When my engine is cold after the night and I start it in the morning, HLA's in left head tick a lot. I have enough engine oil, it is new. When I trun off the engine and start it again, they are all quiet and engine runs perfectly.
Could be problem in oil pressure? Valve in oil pump? Please help, I bought TWO new friction springs because I want to have my engine as quiet as possible and now this happens...
Thank you.
Thank you.
MX-3 V6 1993 | Black | EU-spec | K819
- mitmaks
there's no oil at the HLA when you starting it, once you start it, oil pump pumps it up and lubricates it so no more noise. Pretty typical for HLA's especially in cold weather
- solo_ryder
mine does same thing sometimes
-hec
I have 5w40 Petro Canada Full Synthetic engine oil, SL with freezing point somewhere around -45 C. Ticking continues after few seconds, even after a short drive, only one thing helps - to turn off and start engine again. This sound only comes from the left head. I believe it is only one HLA (according to frequency of ticking).
- mx3autozam
Well, they are known for this, but should not do this. I will try to exchange valve in oil pump. I think there's a problem in oil pressure.. Will let you know. I have also prepared friction spring and nut for replacement. Yesterday, I installed new catalyst, so I am happy. But I also need second oxygen sensor..
