ok so i know everyone is gonna tell me that im crazy for even considering this but i am looking for winter tires for my mx-3 and need some help figuring out what size and a good brand/type to get. i dont have a winter beater and i dont have winter tires as of now...i wont be travelling far throughout the winter so they dont have to be awesome just as long as they keep me on the road.
all help is greatly appreciated. thanks all!!
RTT
Rob
Winter Tires
Well, as small of a diameter rim as you can fit. Going with your stock RS 14's or 15's would probably be best, as well, give you better choice in winter tire types and cheaper prices
Because of the low clearance of your bumper, i'd would probably be better to go with a wheel/tire diameter that is as tall as you can go. Your speedometer will show your going slower than you really are, but if you can get an extra inch in height, the less your call will be a snow plow
Narrow is better, your weight will be less spread, so the car will sink better into the snow, which is good because you want the tires to get it's traction from pavement, not snow.
In terms in which tire, basically even the cheapest winter will outperform the best all seasons. Not only in terms of thread for snow and ice, but even on pavement. Snow tires use a softer compound rubber, so they stick to pavement better than all seasons. As temperature drops, rubber becomes stiffer and grips the road less. Winter tires use a different rubber that will stay significantly softer in cold weather than all seasons. As opposed to what you may hear, winter tires do no wear out faster when driven on pavement (as opposed to snow, etc), they wear out faster in warmer temperatures. Because of the softer rubber, they become much softer in warm weather, so of course they wear out quicker.
I personally dont think your crazy for driving the car over the winter months. Just take a look this year at how many BMWs Lexus and porsches you see. Then think of me, my Mx is my winter beater and Im running some simple eagle GTs 205/55/15 perfectly fine for city winter conditions. also fine when I travel up north.
If the pics on his cardomain page are current, apart form the external body kit, my car is lower and it is purely a winter car.
I am running Toyo Garit winter tires in 195/55/15 size making them just a touch smaller than stock in overall diameter,and with the aforementioned slightly narrower footprint many prefer for snow.
I paid about $470 CDN installed and balanced a year ago. I was initially going to put cheap winter tires on it but it would have save barely over $100. Since i hope to get 3 or 4 winters out of these tires I figured I might as well do it right.
My practice on cars has always been: toss winter tires on the stock rims and then buy bigger rims for summer rubber.
My Summer car is a Porsche.
My Winter car is a 1994 Mazda MX-3 GS. 1.8L V6, K&N intake, Pacesetter Short Shift, Corksports SS Clutch line, Suspension Techniques lowered, Toyo Garit HTs for Winter Grip.
best advised look into getting a set of michlan x-ice i got a set for the x-90 and i'm running bigger tires than all of you and i paid only 375 installed they are pretty amazing i can get great traction in just rear wheel drive and i still havn't thrown in any kind of weight in the rear yet.
yes thats right i don't have my huge 12 in the back of this one had to go with a sealed 10 till i get the chance or time to go and ditch the spare and the make the my fiber glass a new box set up for the trunk, But thats for more warmer weather.
Reaper
Reaper
![Image](http://i81.photobucket.com/albums/j214/reaperofsouls2001/winterx-90.jpg)
