Let's see your engine bays!!
- solo_ryder
I figured I would start one of these threads. I know for a fact that some of you want to show yours off. 4 or 6 cylinder, stock or modded, it don't matter lets see what you got!
Here's my current setup:
- Bling Bling
Looking good. Is that your DE you picked up recently?
Stacy Whitrick
MX-West Calgary
http://www.cardomain.com/ride/1335558 UPDATED June 6,07
94 GS, Green Envy Pearl QUESTION: Does my car fit the RICE category?
MX-West Calgary
- solo_ryder
- JWMX3
arent newer millenias 170 hp and 9.5:1 compression ? Its not a ze if it came from anything on this side of the oceansolo_ryder wrote:After further elaboration with some high-up PT guys it seems it is infact a ZE out of a newer millenia (1998+). So that works for meBling Bling wrote:Looking good. Is that your DE you picked up recently?
- escortluver19
- mitmaks
mine is daily driver, so its by far no show car
- solo_ryder
It was from Japan, I really dont care lol. It runs good and fast so I am happy.JWMX3 wrote:arent newer millenias 170 hp and 9.5:1 compression ? Its not a ze if it came from anything on this side of the oceansolo_ryder wrote:After further elaboration with some high-up PT guys it seems it is infact a ZE out of a newer millenia (1998+). So that works for meBling Bling wrote:Looking good. Is that your DE you picked up recently?
- mx3autozam
- Bling Bling
:2escortluver19 wrote:heres mine.
thumbsup:
Stacy Whitrick
MX-West Calgary
MX-West Calgary
- atlantamx3
Nothing nice to look at because still haven't started the swap yet.
Ever notice anyone driving slower than you is an idiot and anyone driving faster than you is a maniac?
01-03 Civic Projector Swap Tutorial
- XxantwawnxX
that wooden stick holds up my fiberglass hood.
man i really need to do sumthing about my plug wires...
