I know there are many companies that will make custom setups, but im not sure how I would go about telling them exactly what I need. I can give them some basic info like its a 2.5l v6 out of a 97 Probe GT but I dont have the info on detailed specs, like the PT millenia H-Beam rods I have from a BB, I dont know what to tell them about the wrist pins...to tell you the truth i dont really know what "full floating wrist pins" means? Or the Colt Cams (turbo), would they need the lifts and durations and all other cam info? Do i need to know what head gasket i will be using? I know it will be mls gaskets but not sure which brand yet.
Here's what i have so far engine wise:
97 KL Block
Millenia H Beams
ARP head and block studs
Colt Cams (turbo grind)
Curved neck IM
67mm TB
M62 SC
Interprep springs
DE retainers
ZE heads
MBX fpr
I do not have gaskets or bearings yet.
I have my fuel and ignition covered already.
I just got the book "How to tune and modify engine management systems" by Jeff Hartman. Once im through that i will get an EMS, prob not a Mega squirt but well see.
If anyone has any helping info on this topic it would be greatly appreciated, i would like to get my piston headaches dealt with so i can move on to start the assembly over the winter.
Much appreciated
