idle problem
idle problem
hey guys/gals. i have a 1993 mx3 1.6 sohc auto. and everytime i go to stop my car idle's really low and almost stalls but it doent's rpm comes back up to normal, in a few seconds, it has stalled twice so far does anyone know about this problem or has had it? i need help plz! someone
thanks alot
thanks alot
CRAVE
C=car R=race A=adrenaline V=velocity E=engine
- Franko
That used to happen to me when my car was sohc. I never found out what the problem was with it. I think it might be a common thing. I just put a bpt in the car and that fixed it right up. I recommend the same for you. ![Wink :wink:](./images/smilies/icon_wink.gif)
![Image](http://i17.tinypic.com/30idc09.jpg)
did you try adjusting the idle screw on the throttle body?
maybe look for vacuum leaks? our intake piping had some cracks in it that cause a fluctuation in the idle... just replaced it and it came up to a smooth steady idle of 1500.... haha, now I'm going to adjust the idle and bring it down, but I have to find me a screwdriver first![Confused :?](./images/smilies/icon_confused.gif)
EGR? I thought SOHC doesnt have EGR .... does it?Custommx3 wrote:I helped him sort this out over MSN, he has a 16, EGR.
Resetting his ECU seemed to fix it, atleast temporarily.
94 Mx-3 Precidia
- lowflyinmx3
- MechaManZero
My solution as well lmao. Been 7 months since I started cause of the tight money situation. And plus a BPD GTR ain't the easiest thing to get all the parts, time, and money into :pFranko wrote:That used to happen to me when my car was sohc. I never found out what the problem was with it. I think it might be a common thing. I just put a bpt in the car and that fixed it right up. I recommend the same for you.
Çlark
![Image](http://i64.photobucket.com/albums/h192/Mechamanzero/MX-3/2mx3.jpg)
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
- Tropical Emerald 1993
