leaking moonroof
- Mx3Baker
leaking moonroof
My Moonroof and passenger sode window leaks alot of water what to do?
93 Mx-3 GS
5 SPD Conversion
Worklog at
viewtopic.php?f=46&t=54796" onclick="window.open(this.href);return false;
5 SPD Conversion
Worklog at
replace the seals i guess
ProjectMx
My BP and AWD build thread
Cardomain
93 Escort GT daily driving
Cardomain
- PATDIESEL
The moon roof seals (acutally it is a sunroof, moon roofs are the kind that do not pop up out of the car) are a tube that runs from the edge of the seam to the underside of the car. You can blow air through them to clean them out (not alot of pressure though) or it that doesn't work you can take the body panels off and see the tubes. They can also get kicked loose and drain into the floorboard instead of outside. There are four tubes, one at each side of the sunroof. The rears lead to the panel between the door and hatch (B pillar), the fronts obviously go down the A pillar.
On a note though, you may be talking about how when it rains the sela will acutally pour water when you make a turn. This will need a new seal. The door leak, unless you can see the leak, could very well be the sunroof since it leaks into the footwell, as mentioned above, when a drain is clogged. A good way to find where the water is coming in from is to use some talk powder or baby powder on the door seams. Soak the car or let it sit in the rain and you'll see where the talk gets washed away from.
- Mx3Baker
yea it is coming down the door panel mainly by the speaker plus up top in the corner by the sun visor on the head liner it comes in pertty bad also
93 Mx-3 GS
5 SPD Conversion
Worklog at
5 SPD Conversion
Worklog at
check to make sure the end of the hose still goes outside the car.. mine didn't and was leaking inside the car bad
ProjectMx
Cardomain
Cardomain
94 Mx-3 Precidia
