also wondering
Posted: October 8th, 2006, 11:39 pm
hey im wonderig if the 94-95 rs mx3's mass airflow censors will work on the 1993 mx3 1.6liter? trying to get rid of the huge mass airflow censor?
U need it to run the car ur stuck with it unless u put a standalone witch cost from $500-2500 or a map conversion kit which cost $700-1000.crave93 wrote:hey im wonderig if the 94-95 rs mx3's mass airflow censors will work on the 1993 mx3 1.6liter? trying to get rid of the huge mass airflow censor?
Limegreen mx-3 wrote:U need it to run the car ur stuck with it unless u put a standalone witch cost from $500-2500 or a map conversion kit which cost $700-1000.crave93 wrote:hey im wonderig if the 94-95 rs mx3's mass airflow censors will work on the 1993 mx3 1.6liter? trying to get rid of the huge mass airflow censor?
So trying to get rid of the small vane airflow meter is out the ?
Nope, the ECU's are of diffrent OBD systems. As in the computers are not compatable. Although there still is an optioncrave93 wrote:im in the oshawa area. how about you.. and i was wondering if i can use the mass air flow from the 94-95 rs not if i can get rid of mine
thanks
whats the ponit of this. Ur stuck with the VAF in tstock form unless u convert to a map setup or some kind of standalone. Unless he goes one of these routes or another getting rid of the vaf is out the ?. so why am i qouted must be some reason behind it cjthor am just curius,cjthor wrote:Limegreen mx-3 wrote:U need it to run the car ur stuck with it unless u put a standalone witch cost from $500-2500 or a map conversion kit which cost $700-1000.crave93 wrote:hey im wonderig if the 94-95 rs mx3's mass airflow censors will work on the 1993 mx3 1.6liter? trying to get rid of the huge mass airflow censor?
No on both ur ?s guycrave93 wrote:im in the oshawa area. how about you.. and i was wondering if i can use the mass air flow from the 94-95 rs not if i can get rid of mine
thanks
it looks like it same size but a few guys have mention like this guycrave93 wrote:hey how come the vaf of the protege looks exactly the same as my 93 mx3? is it even worth changing?
torpedan wrote: You can sawp on a larger VAF from a older RX-7 if you do some reserach on your own you can see which on is the direct swap.
