mazdaspeed
mazdaspeed
can the newer model mazda speed engines fit into the mx3
1995 J-Spec Az3, BPT swap, mazda speed eibach springs, mazda speed swaybars, mazda speed exhaust, mazda speed shock tower bar, mazda speed bodykit, sr shocks, disk-brakes all around,turbox boost controler, honda del sol act pressure plate, fmic 20x12x3
- atlantamx3
- atlantamx3
- jaydog5678
if the rx-7 had been AWD i would be swapping the rotary in, instead of the of the bp with gtr AWD .... maybe he means the MS6 engine cause that one has a lot of potential
ProjectMx
My BP and AWD build thread
Cardomain
93 Escort GT daily driving
Cardomain
- Josh
you would have a better chance mounting a 302 in there. the problem with the MS 2.0 in the 99 MS PRO, and the newer model 3, would all be hood clearance. its all about the hight of the engine bay. it would fit but could you close the hood? i know with the MS 2.0 you would need to mount the engine lower, or put one hell of a hood scoop on there. i thought about it before. so i went to the wrecker and measured everything out. you could definatly do it, but it would be a bit of custom fabbing for mounts.
