What does it do ... i dont have a plug for it ...
I used all the plugs on the other side to.. this getting weard... No it was on the engine when i got it... hmmm so its knock sensor?johnnyb wrote:possibly the knock sensor?
Looks like the wire runs in behind the intake. The plug for that is on the other side of the engine. Did you re-route that plug?
Its a PITA to do if you don't remove the intake manifold.
zippodk wrote:I used all the plugs on the other side to.. this getting weard... No it was on the engine when i got it... hmmm so its knock sensor?johnnyb wrote:possibly the knock sensor?
What if I just leave it alone will ecu throw a code?
Thats why i asked if somebody had electrical/VRIS wiring for BA because there is apparently no Knock Sensor on KFZE engine/ecu... I want to be shore that i hooked the connections right to check/see if engine can run without it... And report back so that others can see this and help them.... nothing to do that i don't care what you say I appriciate the help alot.lakersfan1 wrote:Look. Apparently, not matter what we say, you're going to say it's already hooked up and we're wrong. It doesn't sound like you're that concerned. We've all tried to tell you it's the knock sensor and you're still denying it, so don't know what else to tell ya.
