stalling idle problems after boosting
My darn cars idle changes after everytime i boost, what the hell is that? Also i dont know what to change my timing to under 6lbs of boost, Anyone know ?
[fs] 92 MX3 gs 2.5 klze v6, Intake, Exhaust,drop zone spring{awsome},Turbo, Splitfire plugs, fmu, gauges ,drilled slotted rotors ,motegi rims,tires,Blackout lights, and a nut behind the wheel~~ so far.
it my guess that the incoming air temperatures wreac havoc with the idle air control. Right after boost the incoming air will be much hotter than before boosting.
I don't think you need to change your timing, and unless you have that megasquirt hooked up you won't be able to anyways.
Andy P. 93 GS 1.8T
Andy P. 93 GS 1.8T
