ok i just installed neon lights and right before i was going to start them up the fuse broke going from the switch to the battery and i cant find it anywhere its pissing me off its a 10amp 250v fuse i was wondering if had to have this fuse or could i change it with another fuse....
any advise will help
fuses
Cant find it?XHurleyX wrote:ok i just installed neon lights and right before i was going to start them up the fuse broke going from the switch to the battery and i cant find it anywhere its pissing me off its a 10amp 250v fuse i was wondering if had to have this fuse or could i change it with another fuse....
http://www.radioshack.com/product/index ... Id=2102753
http://www.radioshack.com/sm-fast-actin ... 03757.html
http://www.wallcoinc.com/Littelfuse_217 ... 7010.v.htm
http://www.shop.com/op/~BUSSMANN_MFG_DI ... urceid=298
94 Mx-3 Precidia
- PATDIESEL
Any 10amp fuse of the same shape and size will work. Almost all fuses are rated at 250 volts now.
