WHAT is wrong with the car???
PeaCheZ
Post by PeaCheZ »
the car doesnt even movein the garage ...i let it run and within 5 min, the car idles at 2000 rpm, then drops slowly goes back up and then drops DRAMATICALLY All the way to zero and stalls!! its not even driveable, i dont understand whats wrong...i need advice and help
twoie
Post by twoie »
wow so little to go on. Check to see if the is a vac leak or a crack in the accordian hose. That' my first two guesses.
twoie
Give us a little more info and I'm sure those who have a much greater knowledge than me will give you some good places to start.
jschrauwen
Post by jschrauwen »
PeaCheZ, first of all, your problem is not unique, it's a "faily common" thing to occur with the MX considering it's age. I suggest as part of a good learning process to search fro some of your potential answers since you'll learn more that way and will be a good catalyst for future problem solving.
Try searching for keywords such as "idle", "surging", "searching", "hunting", "eratic", "fluctuating" in the V6 Performance Forum.
You should come up with something like this;
http://www.mx-3.com/phpbb2/viewtopic.ph ... nting+idle
Here is your original thread started 03 July - http://www.mx-3.com/phpbb2/viewtopic.ph ... ht=surging Do you mean to say that you have not followed any of the recommendations from that 2 page thread? Come on PeaCheZ, there is a bit of a burden of responsability on your part to do your part. It's nearly 2 months later and your opening post says nothing to the effect of what steps you have taken yourself to remedy your problem. It appears that there isn't much done on your part, and if so you made no mention of it in the opening post. That's something we need to go by so that we don't waste ours and your time going over something that's already been covered.
PeaChez - do a search, do some reading, go through the online manual and post back a more descriptive, detailed and perhaps a more insightfull account of what you have, what you have done, what you haven't done and what you think you need to do next. We can surely guide you in the right direction.
Again, the owness is upon yourself again, it's up to you how you approach it and how well you succeed. Good luck.
John
hgallegos915
Post by hgallegos915 »
john very well said. :2thumbsup:
-hec
