cam specs.
SloGsr
cam specs.
Post by SloGsr »
I'm trying to find a factory spec sheet for kl-ze cams and also kl-101 cams. someone has a good deal on a set of kl-ze cams but I only want them if it could be a upgrade like more lift or duration. if any one can help with spec numbers that would be great.
lakersfan1
Post by lakersfan1 »
It's a 4 degree duration increase on both the intake and exhaust. It's also .020 increase in lift.
SloGsr
Post by SloGsr »
thanks for the help. that should give my car a good kick in the pants.
