![Image](http://www.mx-3.com/ubb/smile.gif)
FSZE in an MX-3?
FSZE in an MX-3?
Has anyone thought about the feasability of swapping an FSZE into a MX-3? I understand it would likely require swapping of the F25M-R tranny as well. I think this would be a very interesting swap, as it would give the MX some much needed displacement, while freeing up much engine space over a V6. This engine space could of course be occupied by a turbocharger and associated hardware
Any thoughts?<P>------------------<BR>David Coleman- <B><I>Moderator</B></I><BR><A HREF="http://www.PinkMX-3.com" TARGET=_blank>1993 Mazda MX-3 GS Special Edition</A><BR><B><I>Why get clear tail lights when only Geo Metros are gonna see them?</I></B>
David Coleman
This is an extemely old post, but I'm resurrecting it because of this: http://www.dragtimes.com/Mazda-323-Timeslip-4739.html
Check out what he's running.
'92 Festiva L powered by a 1.8L SOHC Protege motor - For Sale
FSZE's
Give us more info on these engines?
How much power do they make?
Displacement
I never heard of a FSZE
So all that would be needed to do this swap is to swap out the tranny aswell? Everything else will work with it?
Displacement
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- papa roached
i dont see why you cant do an FS swap, we can put the KL motors in ours, MAYBE using the mounts from a PSE or MX-6 it might bolt up but then you got wiring to deal with and axels
- fry_81
not to sound dumb, but what the heck is a FSZE from? lol
familia sport 20 has it.
none of the GE chassis cars have it though, overseas almost none of them even have the FS like we got here...most have a KFZE instead.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- mrspanky79
