KLZE In a 4cyl?
MX3Project2006
KLZE In a 4cyl?
Post by MX3Project2006 »
Went out and bought a 92 MX3 with a 4cyl. My question is that can a klze fit into it? There is not alot of info on this topic if so please help. Looking for the best engine swap and all the info you have on it. Or is this car a waste of time and money?
Tunes67
Post by Tunes67 »
Your answer is yes it will fit.. however.. you claim there is not a lot of information on this.. you are incorrect. This topic has been covered more times than I have hair on my head so maybe you should try searching a bit harder. The engine bay is the same size for ALL versions of the MX3. But there are a lot of reasons why you shouldnt put a V6 into a 4 cyl car. Searching will reveal more details. A more appropriate powerplant for a 4 cyl MX-3 would be a Turbocharged BP engine. Good luck and happy researching :D
Tunes67
Limegreen mx-3
Post by Limegreen mx-3 »
u most have not serch enough like maybe here http://www.mx-3.com/phpbb2/viewforum.ph ... 481dc62fa3 and maybe this http://www.atlantamx3.com/mocaforum/vie ... 07fecde92b
even this guy did this on a MX-3 http://www.mx-3.com/phpbb2/viewtopic.php?t=50776 but that mx-3 had a lot on money invested in it.
mazdamx3sohc
Post by mazdamx3sohc »
your best bet is a n/a bp out of a 94 protege. you will need the ecu with this. and then turboing it seperate. the bpt heads that come stock with turbo flow very very poorly. so no bpt is not the best motor. a bp is and then doing your own bigger than stock turbo for less price.
Tunes67
Post by Tunes67 »
Which ends up being a Turbocharged BP engine as I stated above.. I didnt NOT say a bpt or BPT engine. :roll:
Tunes67
mazdamx3sohc
yeah, but its hard to find a bp that has a turbo on it already, unless your going bpt.
