Rough idel
- xtreme velocity
Rough idel
my car runs fine when i 1st start it..but then when i get it warmed up when i push the clutch in n let it idel it wants 2 die..or sounds like it..i can fugure it out..n i dont wanna mess up the idel..oh n im new at this stuff so pics help me if u explain sumthin 4 me 2 do..thanx guys..sry i havnt been on..i have been on vacation before school starts..thanx again..
Current:
93 F-250 Diesel Coal Roller (For Sale)
06 RX-8 1.3 Rotary AT 6 speed (All looks)
79 Ford Courier 2.3 4cyl 5 speed (lil Pete)
Past:
05 Mazda RX-8 1.3 Rotary MT 6 speed
90 Mazda Miata 1.6L 5 speed 45k miles
94 MX-3 RS DOHC 5 speed 90k miles
Past:
My 95' does somthing similar, when I come to a stop and put it in nutral first it starts to idle around 1100 PRM, then it drops down to 700-800 RPM, and the engine seems to run rough. It's never caused any serious problems. Maybe it's just because it idles so low that it makes the engine seem like it running rough?
- xtreme velocity
mines a 94'..n it does the same thing..i just dont like the feeling it gives when doing what its doing...i dont want 2 mess with the idel tho..i just dont kno what i can do to help it from doin wut its doin..
Current:
Past:
Past:
- xtreme velocity
95_mx-3 wrote:Okay. I finally fixed this problem. My car runs and idles perfect now. This is what I have done in order. My tune up was up, so I was able to drop some money with no problem.
1. Spark plugs
2. Spark plug wire
3. Distributor Rotor & Cap
4. Timing belt
5. Water pump
6. Accessory belts
7. Thermostat
8. Coolant temperature sensor
9. Intake tube(There was a huge crack)
10. PCV Valve
11. Some old vacuum hoses
12. Sea Foamed throttle body, crank case and put some in gas tank
None of the above fixed the problem. We are having over 100 degrees in Texas in these days, and my car died all the time at the stop light especially in the afternoon. I had to turn off the A/C and put in neutral to keep the car running. I didn't want to replace whole distributor unit because it was expensive, but I had no choice. Paid $345 including tax at local dealership. That was with 10% discount. It was rebuild one, so I had to return the core. Anyway, replaced it and guess what? My car runs perfect now. I had knocking noise and it's gone too. Thank god this problem is finally fixed. I guess it'll be good for another 10 years from now on. I hope this helps.
Current:
Past:
Past:
