romsalex wrote:Is similar the Manifold or the flange manifold of a Miata 89-93 1.6L / mx3 91 1.6L ??
I need know to install this manifold in my mx3 1994 Dohc 1.6L
I need plisss if any know this...
the intake manifold from the 1.6 miata will not bolt up to the 1.6 dohcMX-3 both use different size ports and bolt patterns.
The exhaust manifold from the 1.6 miata will bolt up to the 1.6 dohc mx-3 same size ports and bolt patterns. i tried a turbo manifold from the 1.6 maita on the dohc mx-3. engineing laying on the floor.
