Light legalities in ontario?
I want to get blue/bluewhite lights, but what are we allowed to get thats legal in Ontario? Thank you.
White and amber racing forwards and amber and rear facing the rear, those are the laws. Are you looking at getting HID headlights? On that, I'm not sure on the legality. J-Beef posted a nice article on the light types, it's a good read. http://mx-3.com/phpbb2/viewtopic.php?t= ... b0c2b2ccf9
- jschrauwen
Thanks Mike. Noob must learn to use the search. As well make his questions more specific, ie, headlight, taillights, turn signals, side markers, interior lights, add-on lights, aux lights, etc.
My understand is that we are allowed to have any color, the problem is direction, their not allowed to project light facing forward or back. So if you hide the tubes, you should be A-Ok., I've been driving like that for 4 years with my blue underglows and no problem. Just don't drive like an idiot and drive to draw *more* attention to yourself
- vasilaar
This is take from the Ontario Highway Traffic Act
"(1) When on a highway at any time from one-half hour before sunset to one-half hour after sunrise and at any other time when, due to insufficient light or unfavourable atmospheric conditions, persons and vehicles on the highway are not clearly discernible at a distance of 150 metres or less, every motor vehicle other than a motorcycle shall carry three lighted lamps in a conspicuous position, one on each side of the front of the vehicle which shall display a white or amber light only, and one on the rear of the vehicle which shall display a red light only. R.S.O. 1990, c. H.8, s. 62 (1).
Attachment that affects lamps prohibited
(7) No person shall drive upon a highway a motor vehicle if either or both of the lamps that are required on the front of the vehicle by subsections (1), (2) and (3),
(a) are coated or covered with a coloured material; or
(b) have been modified by the attachment to the lamps or the motor vehicle of any device that reduces the effective area of the lenses or the intensity of the beam of the lamps. 2002, c. 18, Sched. P, s. 19 (1).
alright, this is something that affects many of us so here is the laymans...
TECHNICALLY, you are permitted to have ONLY... WHITE... AMBER... and RED.. lamps
now the way that we can get around this (at least in ontario) is dependant on the type of bulb.
as the second part there indicated, ANY Bulb that is COATED is Illegal... so yes... almost every single one of those bulbs that you see in tuner shops... and most of the ones you see online (ebay etc.) are ILLEGAL.... PERIOD... if the glass is blue or purple or whatever colour ur going for... FORGET IT...
however there are certian bulbs... usually a higher quality That give the same effect AND Do not fall under the restricted list.
what you should be looking for are CRYSTALIZED bulbs, they are made in all the normal colours, (HYPER WHITE, BLUE, YELLOW etc.)... but because the colour is actually a result of the type of gas mixing with the GLASS of the Bulb, it is legal.
they are not coated, and therefore are legal.
these bulbs are usually more expensive (ie PIAA etc.) however for someone on a tight(er) budget... look up MTEC... a light company from japan, they specialize in these type of lights.
i am currently running the Golden Style, and i LOVE THEM... and the best part, they still look awesome, however are %100 Legal...
hope this helps
hope this helps
Drive it like you stole it.
