EGR
1REVVIN3
EGR
Post by 1REVVIN3 »
I disconected my egr because it was not working, is there anyway to get rif of the code, beside buying a new egr. Also will the factory oil prssure sensor put the car in limp mode if not connected right.
ariesdude
Post by ariesdude »
EGR codes could be removed - but it requires some external components and a bit of wiring.
Oil pressure sensor is not connected to the ECU i think - it goes directly to the oil pressure light.
94 Mx-3 Precidia
1REVVIN3
Post by 1REVVIN3 »
Do you happen to know what those external components are?, or I diagram.
thanks chad
ariesdude
Post by ariesdude »
I have been thinking of a circuit like this for my ride
I havent tried it yet - so proceed at your own risk.
Edited - to account for ground switching
Edit - tried the new circuit - no codes for 1 1/2 weeks and counting..
94 Mx-3 Precidia
Philthy
Post by Philthy »
Couple of things come to mind when looking at that schematic.
EGR Solenoids are ground side controlled, just like about almost every car since 1980. So that won't work. Also the programming in the ECM for EGR position should be far more sensative than logic looking for fully closed and fully opened. Run with it ariesdude and let us know how it works. i would try something that would gradually increase the egr position sensor and wouldn't split the voltage between the solenoid and the relay, considering charging voltage is at the solenoid and the ecm does the grounding. Also a lot of cars also look at fuel trim to confirm egr flow. Cars using OBD I controls are going to be a lot more forgiving. ( IN the US that means before '96)
This schematic is for a 94 1.6l mx-3
92 MX-3 GS, KL-ZE, OBX headers, 2-1/2" exhaust, XL Performance muffler, AASCO Aluminum flywheel,Pheno spacers,APEXi Airflow computer,Eibach springs,Tockico struts, Toyo RA1 205/50ZR15s, B&M short shifter. MS control arm Bushings, SS clutch line, SS brake hoses
lakersfan1
Post by lakersfan1 »
There is a EPROM maker in California that can make up a K8 EPROM with the EGR code removed. It'll cost you $75 wth the chip installed, if it's worth that much to you.
Philthy
Post by Philthy »
(drum roll) And that company is?....
