KLDE rods and pistons on K8
Jacbs2007
Post by Jacbs2007 »
Well there's a set of DE rods and pistons in the f/s forum. I was hoping you guys could help me out with any information regarding putting these in a K8.
-would I need to change anything ecu or vafm wise?
-would this essentially turn my K8 into a 2.5l hybrid?
-Would it even work without changing the crank etc.
-difficulty of installation?
I'm just looking for any information about this subject, the search function turned up nothing relative to this after about 20 minuts of searching.
1993 GS
-MS front -functional molded hood scoop
-MS molded sides-shaved antenna
-Civic projectors -New black paintjob
kiwi_MX3
Location: Backpacking in Canada in vancouver 13march onwards
Post by kiwi_MX3 »
The K8 Block won't bore out to DE size,
Connecting Rod journal ( DE ) is bigger than K8
So in short NO.
lakersfan1
Post by lakersfan1 »
kiwi_MX3 wrote: Connecting Rod journal ( DE ) is bigger than K8
That's a moot issue since you'd need the KL crank anyways. You can't use the pistons because the bore is WAY too different.
I believe if you use the KL rods and crank, you're at 2.2 liters using K8 pistons.
After the cost of a set of K8 head gaskets, you've already pretty much cost as much as a whole KL long block .......... so the idea is pretty lame anyways.
Steeb
Post by Steeb »
doesnt the k8 and kl use the same block bored to different specs? i thought that is why the kl fits in place of the k8. making a long rod k8 would be nice for boost since it still has thicker cylinder walls. ive been thinking a lot about that lately...
lakersfan1
Steeb wrote:doesnt the k8 and kl use the same block bored to different specs?
It's the same block, but the sleeves are different. Saying they are just bored different implys the that the outer diameter of the sleeve is different, but it's not.
Jacbs2007
Post by Jacbs2007 »
thanks for the responses everyone, i guess it's just gonna be an engine swap now
1993 GS
kiwi_MX3
Post by kiwi_MX3 »
Actully its not a moot point. using std mazda piston's
the deck height of a k8 is
deck height = Ch1.181+Rodcenter5.425+Crank2.74
=9.346
the deck height of a Kl is
deck height = Ch1.181+Rodcenter5.425+Crank2.92
=9.526
so by putting a kl crank in a k8 your going to have pistins popping
up by 0.180"
Sorry the maths say's it all you can't swap parts about. from the
k8 to kl blocks
lakersfan1
There's no way in hell the deck height can be different ........
The same timing belt kit, same cam pulleys, interchangable cams...... if the deck height was different, the timing belt would not be the same, let alone all the other timing parts.
mrspanky79
Post by mrspanky79 »
kiwi_MX3 sorry to say but your wrong in your numbers some where. Im looking out the window and in my drive way theres an mx3 with kl rods and crank in a k8 that runs with no problems. But like stated i would not sugest doing. I only did it becouse i had all the parts lieing around (free) and an uncle that works at a plane plants so all the machening cost me a botle of rum. The big isue is the different pin sizes and getting the rod in the block, rod base is larger then the block bore.
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
kiwi_MX3
Post by kiwi_MX3 »
mrspanky79 wrote:kiwi_MX3 sorry to say but your wrong in your numbers some where. Im looking out the window and in my drive way theres an mx3 with kl rods and crank in a k8 that runs with no problems. But like stated i would not sugest doing. I only did it becouse i had all the parts lieing around (free) and an uncle that works at a plane plants so all the machening cost me a botle of rum. The big isue is the different pin sizes and getting the rod in the block, rod base is larger then the block bore.
Well the Ch of a k8 piston must be very differnt to what is being
quoted on a engine rebuilders site, interesting. will take note of this.
I think we all agree for the poor wee bugger that start out this thread
go and buy a klze.
Any machist vacanices where your uncle works?
lakersfan1
kiwi_MX3 wrote: I think we all agree for the poor wee bugger that start out this thread
go and buy a klze.
Agreed. The only ones that seem to be willing to go out of thier way to not get a ZE are the Euros. They must have some kind of crazy Draconian emissions laws.
Steeb
Post by Steeb »
mrspanky, can you tell us more about your engine build and how it feels? i have a spare ze and a spare k8 sitting in the garage that i plan to do build for future use and i am VERY interested in this setup.
mrspanky79
the pins are different sizes so you have to put bussings in the rods. next the rods dont fit in the bore so I groved the bottom of the bore so you so can put the rods up from the bottom and mechined the piston to hold ring clamps (making them free floating) then assamble the piston onto the roo from the top. As for feel not to sure what it would be on its own my motor is also turbo'd
99 vitara 4x4
Steeb
Post by Steeb »
very nice. thats exactly what i had in mind also and the only reason id build a motor like that for. i was thinking of destroking the kl for that purpose but if the k8 block can be used...
tell me more, if u dont mind. are your k8 heads modified? what turbo are u using?
can the k8 crank fit a kl block?
