egr
gotboost
egr
Post by gotboost »
if you are running a klze with a jdm computer do you need to run with the egr???? the jdm computer shouldn't read the egr. should it
V8KOMX3
Post by V8KOMX3 »
OK before the beasts bite your head off, next time use the search function because this has been covered many times in the past. The answer to your question is no, because JDM does not use egr so you don't need it.
Teal 1993 MX3GSZE
gotboost
Post by gotboost »
thanks for the help much appreciated. I work 16-18 hours a day don't have much time to search page after page to find out what I need to know. thanks again scott
onderground_mx3
Post by onderground_mx3 »
my ZE had the where the EGR was on the K8 blocked off
